[OpenLayers-Users] measure control...
Gery . gamejihou at hotmail.com
Thu Feb 21 14:15:49 PST 2013
if the layer is in utm, I think yes, by default the measurement will be in meters (as far I know). I don't work with geoserver so I can't help you much here, but the value you get can be converted to miles in javascript, you would just need to catch the value before it gets printed.
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
Date: Thu, 21 Feb 2013 14:12:30 -0800
Subject: Re: [OpenLayers-Users] measure control...
To: gamejihou at hotmail.com
CC: openlayers-users at lists.osgeo.org
do you mean that the layer in geoserver controls the measure tool in OpenLayers?
So if the layer in geoserver is UTM -- the measurement tool cannot generate miles ?
What do folks do to make this work as a general solution -- regardless of the projection in the layer?  Do folks who use OpenLayer have to look at the measurement event.units and convert on the OpenLayer javascript side?
On Thu, Feb 21, 2013 at 2:01 PM, Gery . <gamejihou at hotmail.com> wrote:
probably because your base map has utm values, check the projection of your layer.
> Date: Thu, 21 Feb 2013 13:57:53 -0800
> From: sk92129 at gmail.com
> To: openlayers-users at lists.osgeo.org
> I still dont get miles units -- mine still comes out as KM.
> Here is my measure tool .
> measure.html
> <http://osgeo-org.1560.n6.nabble.com/file/n5036001/measure.html>
> Why is it still KM?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/measure-control-tp3942722p5036001.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Sean
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130221/e4262cf4/attachment.html>
