[OpenLayers-Users] drag map with vectorlayers, openlayers 2.12
Christian Ledermann
christian.ledermann at gmail.com
Tue Feb 26 22:48:05 PST 2013
Hello,
With openlayers 2.11 I was able to drag a map with vectorlayers on it by
adding the code (snippet):
var kmls = map.getLayersByClass('OpenLayers.Layer.Vector');
var selectControl = new OpenLayers.Control.SelectFeature(
kmls,
clickout: true,
toggle: true,
multiple: false,
hover: false
selectControl.handlers.feature.stopDown = false;
selectControl.handlers.feature.stopUp = false;
selectControl.handlers.feature.stopClick = false;
map.addControl(selectControl);
selectControl.activate();
for (var i=0; i<kmls.length; ++i){
kmls[i].events.fallThrough = true;
-> http://iwlearn.net/iw-projects/@@project-map-view.html
with openlayers 2.12 this does not work anymore.
How do i get this feature in 2.12?
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
If you save the living environment, the biodiversity that we have left,
you will also automatically save the physical environment, too. But If
you only save the physical environment, you will ultimately lose both.
1) Don’t drive species to extinction
2) Don’t destroy a habitat that species rely on.
3) Don’t change the climate in ways that will result in the above.
