[OpenLayers-Users] Multiple Vector Layers
Alexandre Dubé
adube at mapgears.com
Thu Feb 28 05:56:39 PST 2013
The layers order within the container shouldn't be affected by it and
yes, if that layer container should be the top-most layer if your vector
layers are added last (please, someone correct me if I'm wrong).
You could provide some code or a live example if you have an issue
with this. It would be easier for us to help more.
Regards,
Alexandre
On 13-02-27 11:15 AM, Rob Hyx wrote:
> Thanks Alexandre. So my next question is, should this layer effect the
> z index of the layers it 'contains'? It seems that unless it's the top
> most layer (the container), that the vector layers are pushed below
> the other WMS layers.
> On Wed, Feb 27, 2013 at 8:22 AM, Alexandre Dubé <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
> Hi Robert,
> This layer is an OpenLayers.Layer.Vector.RootContainer object.
> It gets automatically created when you specify an array of layers
> to the SelectFeature control. In short, it was created to solve
> the "I can't click on vectors if they are not in the topmost
> layer" issue. You can read more about this in following ticket :
> http://trac.osgeo.org/openlayers/ticket/1666
> HTH,
> Alexandre
> On 13-02-26 02:27 PM, Rob Hyx wrote:
>> Hello all,
>> I have multiple vector layers on my map, one being just a regular
>> layer I plot GeoJSON to, while the others are KML layers. I have
>> them both using the same OpenLayers.Control.SelectFeature object,
>> and I noticed a 'phantom' layer that is now in the map.layers
>> property called 'openlayers.control.selectfeature_<some
>> number>_container'. My question is, what is this layer? It seems
>> to effect the z indexing of the KML layers, and by that I mean,
>> if the z index of the container is under a raster layer, the KML
>> features are also underneath. Does that make sense?
>> Thanks in advance!
>> Users mailing list
>> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
> Users mailing list
> *HYX*
> http://hyx-music.com
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130228/009eb15b/attachment-0001.html>
