[OpenLayers-Users] divide a map into cells of the same size
Sergeant_york electronicpanda at gmail.com
Thu Jan 3 01:40:50 PST 2013
Here is the solution:
1- You will need a *vector* layer to insert cells (features-geometries)
2- Your visible area is your bounding box with coordinates.
3- you know your bounding box, how many cells do you want to use? let's say
2x2 so you put 4 features on map and their geometries should be polygon with
4 points
4- implement selectfeature for each cell
5- set style of cells how does they look etc
and you are done
you can do this exactly with using openlayers examples:
select feature
add feature
vector layer
styling
extent
bounding box
View this message in context: http://osgeo-org.1560.n6.nabble.com/divide-a-map-into-cells-of-the-same-size-tp5025320p5025415.html
