[OpenLayers-Users] Two displayProjections on a map
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Jan 9 06:57:48 PST 2013
Hi Rich,
Even a map with three projections, in meters, feet and degrees. And so
easy to make, if you know how to.
Cheers,
Jan
On 1/9/2013 3:54 PM, Richard Greenwood wrote:
> On Wed, Jan 9, 2013 at 5:40 AM, Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
> Is it possible to have tow displayprojections on a map? I would
> like to show the actual mouse position both in WGS84 latlon
> (epsg:4326) and in the projection of the map I am working on.
> Changing the projection in the Javascript file and starting the
> application anew does the trick, but I would like to see both
> coordinate pairs at the same time. Is there a trick to do this?
> Jan
> Sure! Here's an example:
> http://maps.greenwoodmap.com/tetonwy/mapserver/map
> <http://maps.greenwoodmap.com/tetonwy/mapserver/map>
> Richard Greenwood
> richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>
> www.greenwoodmap.com <http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130109/40188be2/attachment.html>
