[OpenLayers-Users] OGC Filter problem
pask23
lzpasquale at gmail.com
Thu Jan 10 08:19:39 PST 2013
maybe I have found the error. Geoserver to do this query on the DB:
SELECT "node_id","datetime","geom".STAsBinary() as "geom"
FROM "v_dati_sensori_geom_BNU1" WHERE "datetime" BETWEEN '2013-01-3
16:45:53.000' AND '2013-01-10 16:45:58.000'
but this not work because the right query on SQL SERVER is:
BETWEEN convert(datetime, '2013-01-3 16:45:53.000', 30) AND
convert(datetime, '2013-01-10 16:45:58.000', 30)
Workaround for this problem?
View this message in context: http://osgeo-org.1560.n6.nabble.com/OGC-Filter-problem-tp5026627p5026705.html
