[OpenLayers-Users] RegularPolygon radius document questions
杨华杰
yhjhoo at gmail.com
Tue Jan 29 00:18:02 PST 2013
eg. I want to draw a circle on the map, the radius is 4KM.
On Tue, Jan 29, 2013 at 4:11 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
> can set up it individual? This is a global setting.
> On Mon, Jan 28, 2013 at 6:45 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
>> nice, thank you very much, it help me a lot
>> On Mon, Jan 28, 2013 at 4:38 PM, Grégory COLLIN <gcollin at v3d.fr> wrote:
>>> Le Mon, 28 Jan 2013 08:15:48 +0100,
>>> 杨华杰 <yhjhoo at gmail.com> a écrit :
>>> > Hi
>>> > I have a question about the document.
>>> > Here is the URL:
>>> http://dev.openlayers.org/docs/files/OpenLayers/Handler/RegularPolygon-js.html#OpenLayers.Handler.RegularPolygon.setOptions
>>> > The
>>> > radius<
>>> http://dev.openlayers.org/docs/files/OpenLayers/Handler/RegularPolygon-js.html#OpenLayers.Handler.RegularPolygon.radius
>>> > explain as {Float} Optional radius in map units of the regular
>>> > polygon.
>>> > What's the unit? kilometer/meter/mile/NM?
>>> > Regards,
>>> > Hua Jie
>>> Hi Hua Jie,
>>> The units requested could be defined in the map object.
>>> So here is the code sample i used :
>>> var map = new OpenLayers.Map({
>>> div: "map",
>>> theme: null,
>>> units: 'm',
>>> projection: "EPSG:900913",
>>> controls: [
>>> new OpenLayers.Control.Navigation({zoomWheelEnabled: false}),
>>> new OpenLayers.Control.NavToolbar({zoomWheelEnabled: false}),
>>> new OpenLayers.Control.PanZoomBar(),
>>> new OpenLayers.Control.ScaleLine()]
>>> So you can add the unit you want in this constructor.
>>> according to the documentation :
>>> http://dev.openlayers.org/releases/OpenLayers-2.6/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.units
>>> you can specify : ‘degrees’ (or ‘dd’), ‘m’, ‘ft’, ‘km’, ‘mi’, ‘inches’.
>>> Enjoy,
>>> Best regards.
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130129/642c9cc3/attachment-0001.html>
