[OpenLayers-Users] OpenLayers.Class with OpenLayers.Control.GetFeature
Gery . gamejihou at hotmail.com
Wed Jan 30 07:52:20 PST 2013
Hi all,
I'm wondering if someone could point me in the right direction to force the BBOX of OpenLayers.Control.GetFeature to be always in long/lat coordinates. I'm trying to get this with OpenLayers.Class, so the new control will inherit OpenLayers.Control.GetFeature with just the small modification in BBOX. This is what I've done:
OpenLayers.Control.myGetFeature = OpenLayers.Class(OpenLayers.Control.GetFeature,{
            selectBox: function(position){
                var opts = OpenLayers.Control.GetFeature(position);
                var baseSRSutm = this.map.getprojectionObject();
                var layerSRSdd = new OpenLayers.Projection('EPSG:4326');
                opts.params.bbox =
this.map.getExtent().transform(baseSRSutm,layerSRSdd).toBBOX(null,firstLayer.reverseAxisOrder());
            return opts;
but I'm getting that some "}" are missing. Is this the right way to use OpenLayers.Class to do what I want?
Any help is much appreciated.
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130130/4016b0eb/attachment.html>
