[OpenLayers-Users] OpenLayers.Class withOpenLayers.Control.GetFeature
Arnd Wippermann arnd.wippermann at web.de
Wed Jan 30 14:34:13 PST 2013
try this:
opts.params.bbox = ...
return opts;
CLASS_NAME: "OpenLayers.myGetFeature"
It seems, that a class needs a CLASS_NAME.
Arnd
  _____
Von: Gery . [mailto:gamejihou at hotmail.com]
Gesendet: Mittwoch, 30. Januar 2013 18:53
An: arnd.wippermann at web.de
Cc: openlayers-users at lists.osgeo.org
Betreff: RE: AW: [OpenLayers-Users] OpenLayers.Class
Thanks for that Arnd, now it stops complaining about the missing "}", but
now it appears "TypeError: this.CLASS_NAME is undefined", what and where
should I put there?
____________________________________________________________________________
______________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO
es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie
es NICHT, wenn es NICHT notwendig ist.
  _____
To: gamejihou at hotmail.com
CC: openlayers-users at lists.osgeo.org
Subject: AW: [OpenLayers-Users] OpenLayers.Class
Date: Wed, 30 Jan 2013 18:13:50 +0100
move 'return opts;' into the function body:
return opts;
to get rid of the error.
Arnd
  _____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Gery .
Gesendet: Mittwoch, 30. Januar 2013 16:52
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] OpenLayers.Class
Hi all,
I'm wondering if someone could point me in the right direction to force the
BBOX of OpenLayers.Control.GetFeature to be always in long/lat coordinates.
I'm trying to get this with OpenLayers.Class, so the new control will
inherit OpenLayers.Control.GetFeature with just the small modification in
BBOX. This is what I've done:
OpenLayers.Control.myGetFeature =
OpenLayers.Class(OpenLayers.Control.GetFeature,{
            selectBox: function(position){
                var opts = OpenLayers.Control.GetFeature(position);
                var baseSRSutm = this.map.getprojectionObject();
                var layerSRSdd = new OpenLayers.Projection('EPSG:4326');
                opts.params.bbox =
this.map.getExtent().transform(baseSRSutm,layerSRSdd).toBBOX(null,firstLayer
.reverseAxisOrder());
            return opts;
but I'm getting that some "}" are missing. Is this the right way to use
OpenLayers.Class to do what I want?
Any help is much appreciated.
Gery
______________
es necesario.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130130/371c6ced/attachment-0001.html>
