[OpenLayers-Users] documentation
Jim White
jbw2003 at earthlink.net
Wed Jan 30 20:05:53 PST 2013
Thanks Matt,
I see that if you look in the source there are 2 different APIs also. I
suppose you should try to build to the public API and resort to using
the dev API when things don't work.
Jim
Actually, that is an intentional
difference.
The 1st link is to the 2.12 release API documentation. This is
limited (by design) to public API methods (as marked in the docs
within the code). Also since it is tied to the 2.12 release, it is
a static snapshot of the api at the time of the latest 2.12
release. The API methods are not supposed to change between
releases and require at least 2 release cycles of deprecation
warnings before being moved to the deprecated file and even then,
by including the deprecated.js file, you can still get them back
While, the 2nd link is to the 'trunk' or 'nightly' developer
documentation. This documentation includes every documented method
in every class and is updated every time a commit is made to the
master branch of OpenLayers. The non-API methods may change or
even be removed entirely between releases without warning or
notice. Thus this documentation presents a very different view of
the class methods and properties than the API documentation
James B. White
Cary, NC
H: 919-380-9615
M: 919-698-1765
White Coding and Maps <http://whitecodingandmaps.com/>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130130/05218859/attachment.html>
