[OpenLayers-Users] What is the function used to switch between GoogleMaps layers in OpenLayers ?
theog Bobosh23 at hotmail.com
Tue Jul 2 07:26:58 PDT 2013
I am trying to use Google Maps' layers from Openlayers with this following
code :
map = new OpenLayers.Map('myMap', {
        projection: 'EPSG:3857',
        layers: [
            new OpenLayers.Layer.Google(
            	"Google Streets", // the default
            	{numZoomLevels: 20}
                "Google Physical",
                {type: google.maps.MapTypeId.TERRAIN}
                "Google Hybrid",
                {type: google.maps.MapTypeId.HYBRID, numZoomLevels: 20}
                "Google Satellite",
                {type: google.maps.MapTypeId.SATELLITE, numZoomLevels: 22}
        center: new OpenLayers.LonLat(lon, lat)
            // Google.v3 uses web mercator as projection, so we have to
            // transform our coordinates
            .transform('EPSG:4326', 'EPSG:3857'),
        zoom: 5
    map.addControl(new OpenLayers.Control.LayerSwitcher());
I am facing an issue in displaying the map even if I can interact with the
map as you can see :
<http://osgeo-org.1560.x6.nabble.com/file/n5063578/GoogleMapOpenLayersIssue.png>
However, when I try to switch the layer, it works perfectly.
That's why I am asking this question :
How does it work and what does it call ?
I would like to know how this function is made to use it at the beginning of
my initialization.
I watched in the structure of OpenLayers but I couldn't find it...
Regards,
Theo.
View this message in context: http://osgeo-org.1560.x6.nabble.com/What-is-the-function-used-to-switch-between-GoogleMaps-layers-in-OpenLayers-tp5063578.html
