[OpenLayers-Users] OpenLayers.Map.render possible bug
Andreas Hocevar
ahocevar at opengeo.org
Mon Jul 8 06:41:50 PDT 2013
Can you be a bit more specific and explain what you mean by "container is
split in two"? A screenshot maybe?
Thanks,
Andreas.
On Mon, Jul 8, 2013 at 2:05 PM, Nuno Magalhães <nuno.magalhaes at inov.pt>wrote:
> If I write the following code:
> var resizeTimeoutId;
> function schedulePageResize() {
> clearTimeout(resizeTimeoutId);
> resizeTimeoutId = setTimeout('doPageResize();', 10);
> function doPageResize() {
> //Refresh map (sometimes needs this to reposition map correctly)
> //OpenLayers-2.12 needs this to reposition vector data correctly
> myMapObj = this.document.getElementById('myMap');
> if (map != null) map.render(myMapObj);
> and call it on the body "onresize" event handler the container is split in
> two (in the latest version of open layers - 2.13). Why?
> I attach the html file that causes this issue.
> page.html <http://osgeo-org.1560.x6.nabble.com/file/n5064681/page.html>
> http://osgeo-org.1560.x6.nabble.com/OpenLayers-Map-render-possible-bug-tp5064681.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130708/5adcb020/attachment-0001.html>
