[OpenLayers-Users] Error when adding OpenLayers.Control.OverviewMap
Claudio V.
claudio.carvalho at lemaf.ufla.br
Wed Jul 10 07:27:59 PDT 2013
I second Alexandre, i think you'll need to add some layers on the
constructor. The overview control expects a base layer to be set or that
you supply some, otherwise it'll have nothing to display.
2013/7/10 Alexandre Dubé <adube at mapgears.com>
> Hi Robert,
> You could try to create your overview map with its own layers:
> new OpenLayers.Control.OverviewMap({
> layers: [
> new OpenLayers.Layer...
> HTH,
> Alexandre
> On 13-07-10 07:34 AM, Rob Hyx wrote:
> Alexandre, thanks for your reply.
> I did try adding the control in via Firebug just from the console after
> the page has fully loaded and I get the same error. From looking at the
> call stack in FB:
> zoomToExtent(bounds=-180,-90,180,90 { left=-180, bottom=-90, right=180,
> more...}, closest=undefined)
> zoomToMaxExtent(options=undefined)
> createMap()
> update()
> draw()
> addControlToMap(control=Object { layers=[1], handlers={...},
> displayClass="olControlOverviewMap", more...}, px=undefined)
> addControl(control=Object { layers=[1], handlers={...},
> So it's the call to zoomToMaxExtent() in createMap() that does it. I can
> see in draw() that there are layers being assigned to the overview (the
> baseLayer of the the actual map object), but no baseLayer property.
> Alexandre Dubé
> Mapgearswww.mapgears.com
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130710/04b063b8/attachment.html>
