[OpenLayers-Users] OpenLayers.Protocol.HTTP and Asynchronous request
islanis at infomed.sld.cu
Fri Jul 19 03:50:05 PDT 2013
"Diego Guidi" <diegoguidi at gmail.com> escribió:
> why simply not start request 2 after request 1, i.e inside the
> callback response from request 1?
In the last instance, i am gonna to do that, but if i do that i have
to introduce all the rest of code inside the callback request, and i
dont want to do that, i know that openlayers use XMLHttpResquest
object to do do all the requests, in some where must be a place or a
tweak where i can activate or deactivate to turn off the
asynchronous's transactions mode, that will be a clean job, in other
way will not, but thanks.
> Diego Guidi
> On Fri, Jul 19, 2013 at 1:36 AM, J.Alejandro Martinez Linares
> <islanis at infomed.sld.cu> wrote:
>> Hi people i need hel from you, i need to do some synchronized tasks by order
>> and using
>> OpenLayers.Protocol.HTTP i can't do it because the request are not made by
>> order, please help how coud i fix this
>> i execute this:
>> var grenseProtocol = new OpenLayers.Protocol.HTTP({
>> format: new OpenLayers.Format.GML(),
>> async: false,
>> url: "http://" + host + "/geoserver/wfs",
>> params: {
>> service: "WFS",
>> request: "GetFeature",
>> version: "1.0.0",
>> typename: featureTypes,
>> filter: filterStr
>> //llamamos al WFS
>> grenseProtocol.read({
>> readWithPOST: true,
>> callback: function(resp) {
>> console.log('1');
>> console.log('2');
>> and the result is this
>> 2
>> 1
>> int firebug and it would be like this:
>> 1
>> 2
>> thanks to all
>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>> Nacional de Salud. La persona que envia este correo asume el compromiso de
>> usar el servicio a tales fines y cumplir con las regulaciones establecidas
>> Infomed: http://www.sld.cu/
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
