[OpenLayers-Users] Best practice for many points
remi remiglobal at gmail.com
Mon Jul 29 07:18:40 PDT 2013
In one of our application,  we slice the request back to the server to
smaller chunks. Each chunk requests 10 features.
All request, are using the html5 worker threading method. In this case it
forbids the browser from hanging.
We are not using KML like u do. Moreover our method is not sofisticated but
it is working just right  for us.
Hope it helps.
Remi
On 29 Jul 2013 21:35, "Claudio V." <claudio.carvalho at lemaf.ufla.br> wrote:
> Hi, just to be sure, you mean more than 1,000 points/markers (not polygons
> or lines)? In the only experience I had with that many points I wasn't
> loading the KML through OpenLayers.Layer.Vector (as in
> http://openlayers.org/dev/examples/kml-layer.html, for example). We had a
> 'upload' dialog, so that the user could choose a file from his machine. We
> then used the KML Parser to extract the features and then added to a layer.
> This way we were able to display around 20,000 markers (before things
> started to get slow). If what you're doing is something similar I could
> give you some hints.
> 2013/7/28 Phil Scadden <p.scadden at gns.cri.nz>
>>  What is the best practice to plot more than 1,000 itens from a KML file?
>>> I have tried cluster strategy, but it still takes too much time.
>>> Any clue is welcome!
>> I would say best practise is dont use any vector format for more than 500
>> points of geometry, period. And KML can be considerably more verbose than
>> say GML. You are up against limitations of the browser, network transfer
>> speeds and especially the execution speed of js. Have a long look at the
>> application and see how you move rendering to the server (WMS). If you are
>> stuck with KML, then look at the KML module in geoserver for example.
>> Notice: This email and any attachments are confidential.
>> If received in error please destroy and immediately notify us.
>> Do not copy or disclose the contents.
>> ______________________________**_________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
> Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130729/3e5473fa/attachment-0001.html>
