[OpenLayers-Users] Accessing user defined data from a OpenLayers application
Nipuni Perera
nipuni880917 at gmail.com
Tue Jun 4 03:52:05 PDT 2013
I am trying to read a KML file from a URL, instead of a local file. Below
is my code for initializing the vector layer. But it does not work.
(Reading from the local file worked fine)
vector_layer = new OpenLayers.Layer.Vector("KML", {
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "http://api.flickr.com/services/feeds/geo/",
params:{'format':'kml','tags':'bird'},
format: new OpenLayers.Format.KML({
extractStyles: true,
extractAttributes: true,
maxDepth: 2
Thanks,
Nipuni
On Sat, May 25, 2013 at 6:11 PM, Nipuni Perera <nipuni880917 at gmail.com>wrote:
> Hi Grey,
> It works fine, Thanks
> Thanks,
> Nipuni
> On Sat, May 25, 2013 at 5:32 PM, Nipuni Perera <nipuni880917 at gmail.com>wrote:
>> Hi,
>> This is also not working, it may be an issue with my server. Thanks
>> Thanks,
>> Nipuni
>> On Sat, May 25, 2013 at 4:16 PM, Gery . <gamejihou at hotmail.com> wrote:
>>> it looks good to me, probably modifying your code like this?:
>>> url: "kml/YOUR-KML.kml",
>>> maxDepth: 2
>>> __________________________________________________________________________________________
>>> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas
>>> si NO es necesario.
>>> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
>>> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
>>> Sie es NICHT, wenn es NICHT notwendig ist.
>>> Date: Sat, 25 May 2013 14:24:47 +0530
>>> Subject: Re: [OpenLayers-Users] Accessing user defined data from a
>>> From: nipuni880917 at gmail.com
>>> To: gamejihou at hotmail.com
>>> CC: p.scadden at gns.cri.nz; openlayers-users at lists.osgeo.org
>>> This is the KML file I am using. I have tried with some other KML files,
>>> but still it does not work.
>>> Thanks,
>>> Nipuni
>>> On Sat, May 25, 2013 at 2:07 PM, Gery . <gamejihou at hotmail.com> wrote:
>>> Probably the kml structure is wrong, is it?
>>> Sent from my iRon
>>> On May 25, 2013, at 9:14, "Nipuni Perera" <nipuni880917 at gmail.com>
>>> wrote:
>>> Hi,
>>> I have tried displaying data from GeoJSON file which worked fine with
>>> both localhost and local file location. But when I tried to get data from a
>>> KML file it does not show data on the vector layer, only the base layers is
>>> visible.
>>> This is my vector layer instantiation for retrieving KML data.
>>> vector_layer = new OpenLayers.Layer.Vector('KML Data',
>>> { projection:new OpenLayers.Projection('EPSG:4326'),
>>> protocol:new OpenLayers.Protocol.HTTP({url:'flicker_data.kml',
>>> format:new OpenLayers.Format.KML({extractAttributes:true})})
>>> ,stratagies:new OpenLayers.Strategy.Fixed()});
>>> Thanks,
>>> Nipuni
>>> On Thu, May 9, 2013 at 10:34 AM, Phil Scadden <p.scadden at gns.cri.nz>wrote:
>>> >If so (correct me if my approach incorrect), where should I put the
>>> data that I need to access from the OpenLayers application?.
>>> >Do I need to save data in a file or does the data need to be available
>>> from a server?.
>>> I am assuming that your application will run off a server? If so, then
>>> no problem putting the data as xml file on that server and using http to
>>> access it (eg, that is how you normally fetch GML).
>>> If you are working "server-less" then its a whole different ball game.
>>> For starters you will need to use a script protocol to get around browser
>>> security restrictions on local files. To make your life easier, if at all
>>> possible use a server. If you can feed your data to a spatial database like
>>> PostGIS and extract with WMS/WFS server like geoserver or mapserver, then
>>> it will be easier still.
>>> Notice: This email and any attachments are confidential.
>>> If received in error please destroy and immediately notify us.
>>> Do not copy or disclose the contents.
>>> ______________________________**_________________
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
>>> Nipuni Piyabasi Perera
>>> Undergraduate
>>> Department of Computer Science And Engineering
>>> University of Moratuwa
>>> Sri Lanka
>>> Users mailing list
>>> Undergraduate
>>> Sri Lanka
>> Undergraduate
>> Sri Lanka
> Undergraduate
> Sri Lanka
Undergraduate
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130604/58606688/attachment-0001.html>
