[OpenLayers-Users] WFS layer not visible
Raffaele Morelli
raffaele.morelli at gmail.com
Tue Jun 4 22:00:51 PDT 2013
2013/6/5 Nipuni Perera <nipuni880917 at gmail.com>
> Hi,
> Yes I have Python installed and the first line of the proxy.cgi is
> #!C:/Python33/python.exe -u
> which points to the python.exe location.
> I have set the changes to httpd.conf file as described here<http://vijaysambhe.wordpress.com/2012/10/12/openlayers-cross-domain-configure-proxyhost-on-windows/>.
> I have reinstalled Python and the response change from the script to an
> error message. This is the response I received for the POST request:
> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>500 Internal Server Error</title></head><body><h1>Internal Server Error</h1><p>The server encountered an internal error ormisconfiguration and was unable to completeyour request.</p><p>Please contact the server administrator, admin at example.com and inform them of the time the error occurred,and anything you might have done that may havecaused the error.</p><p>More information about this error may be availablein the server error log.</p></body></html>
> This is the same error message I get when I try to open the proxy.cgi from localhost.
> Thanks,
> Nipuni
You should have a look at apache error log, it's clearly a misconfiguration
in apache (error 500) and what you need for debug is there.
I would suggest to check directory and/or file permissions (ie. virtual
host configuration directives).
/r
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130605/12f82063/attachment.html>
