[OpenLayers-Users] GPX with empty labels
Andreas Hocevar
ahocevar at opengeo.org
Mon Jun 10 00:57:20 PDT 2013
See http://trac.osgeo.org/openlayers/ticket/1439 for the ticket where
this change was discussed. And note that it is 5 years old, so I
wonder what version you were using when you got a result that worked
for you. The ticket also suggests using a regular expression instead
of an isNaN check. Maybe you want to create a pull request?
Andreas.
On Sun, Jun 9, 2013 at 11:34 PM, Martin Mares <mj at ucw.cz> wrote:
> Hi!
>> this approach should also fail with older versions of OpenLayers. At least
>> the code section you pointed out did not change between 2.12 and 2.13. If
>> you are talking about a previous version, you must be talking about
>> something very old (2.9 or 2.10 maybe?).
> It was about a year ago, so it's probably something very old :)
>> Instead of adding the overhead to render tracks with an empty label, why
>> don't you either use a rule based style that only renders labels for points
>> or a context function that returns undefined for tracks?
> Thanks, but it solves only a part of the problem, not the automatic
> conversion of "00" to "0".
> I still feel that features with empty names, or named as "000" should
> work out of the box, so I am probably doing something terribly wrong
> if they don't.
> Have a nice fortnight
> Martin `MJ' Mares <mj at ucw.cz> http://mj.ucw.cz/
> Faculty of Math and Physics, Charles University, Prague, Czech Rep., Earth
> Even nostalgia isn't what it used to be.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
