[OpenLayers-Users] getCapabilities
Arnd Wippermann
arnd.wippermann at web.de
Wed Jun 12 10:02:39 PDT 2013
You can access data from a remote server only by a proxy script, that
resides on your web server.
Search for "same origin policy"
http://docs.openlayers.org/library/request.html
Arnd
-----Ursprüngliche Nachricht-----
Von: Helmut Seidel M.A. [mailto:info at knowhow-la.de]
Gesendet: Mittwoch, 12. Juni 2013 14:38
An: arnd.wippermann at web.de; openlayers-users at lists.osgeo.org
Betreff: AW: [OpenLayers-Users] getCapabilities
Hello again,
thank you for your answer. I've tried your code but keep getting the
message:
NS_ERROR_DOM_BAD_URI: Access to restricted URI denied
oRequest._object.send(oRequest._data);
XMLHttpRequest.js (Zeile 220)
I've tried several Datasources to the same result - I'f I use QGis or Python
OSWLib everything works fine?
Thanks again
Helmut
The code I've used is:
OpenLayers.ProxyHost = "proxy.cgi?url=";
function init()
var request = OpenLayers.Request.GET({
url:
"http://geodaten.bayern.de/ogc/ogc_dtk50_oa.cgi?service=WMS&request=GetCapab
ilities&version=1.1.1",
success: function(response){
var xml = request.responseXML;
var format = new
OpenLayers.Format.WMSCapabilities({version:"1.1.1"});
var GetCapabilities = format.read(xml);
var capability = GetCapabilities.capability;
var WMS_Title = GetCapabilities.service.title;
var WMS_Abstract =
GetCapabilities.service.abstract;
var OnlineResource =
GetCapabilities.capability.request.getmap.href;
var Msg = "";
Msg += WMS_Title + "\n\n";
Msg += WMS_Abstract + "\n\n";
Msg += OnlineResource + "\n\n";
for (var i=0; i < capability.layers.length; i++) {
layer = capability.layers[i];
Msg += layer.title + " :: " + layer.name + "\n";
alert(Msg);
</script>
</head>
<body onload="init();">
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Arnd
Wippermann
Gesendet: Dienstag, 11. Juni 2013 21:11
An: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] getCapabilities
you have missed one level.
and you need a proxy script to get the response from a remote server.
that should work:
function init()
url:
"http://geodaten.bayern.de/ogc/ogc_dop200_oa.cgi?service=WMS&request=GetCapa
bilities&version=1.1.1",
var format = new
var WMS_Abstract = GetCapabilities.service.abstract;
var Msg = "";
alert(Msg);
init();
Arnd
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Helmut
Seidel M.A.
Gesendet: Dienstag, 11. Juni 2013 17:25
An: 'Bart van den Eijnden'
Cc: openlayers-users at lists.osgeo.org
Hello again,
I've changed the code to someting like:
function init(){
url:
var format = new
OpenLayers.Format.WMSCapabilities();
var capabilities = format.read(xml);
for (var i=0; i < capabilities.layers.length;
i++) {
layer =
capabilities.layers[i];
alert(layer.name);
But that does not really improve things, so I guess that's not what you've
meant- sorry I'm really new to OpenLayers.
Thanks again
Helmut
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
