[OpenLayers-Users] TypeError: OpenLayers.Control.EditingToolbar is not a constructor
Tonton to.tonton at gmail.com
Fri Jun 28 02:13:42 PDT 2013
Yes i use OL embeded with the horde framework
i replace it with OL stable just downloaded and i have this
error
TypeError: this.map.addControl is not a function
this.map.addControl(new OpenLayers.Control.EditingToolbar(vlay));
any
idea ?
On Thu, Jun 27, 2013 at 7:27 PM, Alexandre Dubé <adube at mapgears.com> wrote:
>  Hi,
>   Are you using a builded version of OpenLayers, like
> OpenLayers.light.debug.js maybe ?  If so the
> OpenLayers.Control.EditingToolbar might not included in the build you're
> using.  If you enter "OpenLayers.Control" in your navigator dev tool,
> you'll see what controls your build contains.
>   That would be the first thing I'd check.  Try switching to
> OpenLayers.debug.js or OpenLayers.js to see if it works.
> HTH,
> Alexandre
> On 13-06-27 10:57 AM, Tonton wrote:
> I try to add editing tools bare after the map was created
> var vlay = this.map_layers[1];
>                console.log(vlay);
>                 var editing = new OpenLayers.Control.EditingToolbar(vlay);
>                 this.map.addControl(editing);
>  and systematicaly i had this error message
>  the console. log output :
> Object { EVENT_TYPES=[28], options={...}, name="Editable", more...}  is
> the layer i want to draw on
>  What i 'am doing wrong ?
> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> Mapgearswww.mapgears.com
> Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130628/624a8bf1/attachment.html>
