[OpenLayers-Users] Fwd: TypeError: OpenLayers.Control.EditingToolbar is not a constructor
Tonton to.tonton at gmail.com
Fri Jun 28 07:22:04 PDT 2013
You right !
i've map in my map object so
this.map.map.addcontrol  working !
regards
On Fri, Jun 28, 2013 at 2:27 PM, Alexandre Dubé <adube at mapgears.com> wrote:
>  Use Firebug or any browder dev tools to inspect your code.  Put break
> points, watch your variables content and you'll discover what's wrong.
> HTH,
> Alexandre
> On 13-06-28 05:13 AM, Tonton wrote:
>  Yes i use OL embeded with the horde framework
>  i replace it with OL stable just downloaded and i have this
> error
> TypeError: this.map.addControl is not a function
> this.map.addControl(new OpenLayers.Control.EditingToolbar(vlay));
> any
> idea ?
> On Thu, Jun 27, 2013 at 7:27 PM, Alexandre Dubé <adube at mapgears.com>wrote:
>>  Hi,
>>   Are you using a builded version of OpenLayers, like
>> OpenLayers.light.debug.js maybe ?  If so the
>> OpenLayers.Control.EditingToolbar might not included in the build you're
>> using.  If you enter "OpenLayers.Control" in your navigator dev tool,
>> you'll see what controls your build contains.
>>   That would be the first thing I'd check.  Try switching to
>> OpenLayers.debug.js or OpenLayers.js to see if it works.
>> HTH,
>> Alexandre
>> On 13-06-27 10:57 AM, Tonton wrote:
>>  I try to add editing tools bare after the map was created
>> var vlay = this.map_layers[1];
>>                console.log(vlay);
>>                 var editing = new OpenLayers.Control.EditingToolbar(vlay);
>>                 this.map.addControl(editing);
>>  and systematicaly i had this error message
>>  the console. log output :
>> Object { EVENT_TYPES=[28], options={...}, name="Editable", more...}  is
>> the layer i want to draw on
>>  What i 'am doing wrong ?
>>  _______________________________________________
>> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Alexandre Dubé
>> Mapgearswww.mapgears.com
>> Users mailing list
> Alexandre Dubé
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130628/69301d45/attachment.html>
