[OpenLayers-Users] ModifyControl Select/Delete Vertex?
Alexandre Dubé
adube at mapgears.com
Fri Mar 1 07:13:30 PST 2013
Something like that, yeah. If you could create a small example that
reproduces and explains the issue using 2.12, posting it live then
sending a new message on the OpenLayers "dev" mailing list, you'd get a
greater chance to have a core OpenLayers dev reply with a fix/solution.
I'd follow that with great interests.
Regards,
Alexandre
On 13-03-01 10:00 AM, Robert Smart wrote:
> And I’ve also just figured out that if you delete a vertex using my
> code, it stops responding to the click event, but if you then drag
> that point, it will start responding again.
> So it looks like dragging it somehow resets the event handler?
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130301/f9a934fa/attachment.html>
