[OpenLayers-Users] Need help for Cluster strategy using externalGraphic
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sat Mar 2 10:13:52 PST 2013
It's not an easy task.
For styles you can use something like:
var myClusterStyleMap = OpenLayers.StyleMap({
'default': new OpenLayers.Style({
externalGraphic: '${myGrafic}',
label: '${count}',
context: {
count: function(feature) {
if (feature.cluster) { // is `.cluster` the array of
clustered features
return feature.cluster.length; // or
feature.attributes.count, is the same
} else { // is not clustered
return ''; // no label
myGrafic function(feature) {
return ...my-cluster-grafic;
} else {
return ...my-feature-grafic;
Watch this proposal that allows easier use of popups and tooltips with the
clusters:
http://jorix.github.com/OL-FeaturePopups/examples/feature-popups.html
Regards,
Xavier Mamano
robertico wrote
> I've markers on my map after loading a kml file.
> <br>
> <br>
> The (default) icon is loaded from the kml file (
> extractStyles: true
> <br>
> I've also using a popup form for the kml markers. (
> extractAttributes
> <br>
> <br>
> I'd like to use cluster strategy but don't understand how to use it.
> <br>
> The only thing I need is to display a different icon for the clustered
> markers.
> <br>
> No fancy stuf like animated markers. Just a default icon for the non
> clustered markers
> and another one for the clustered markers.
> <br>
> <br>
> the final result should be;
> <br>
> - An icon for clusterd markers and after a marker click a popup form
> showing the number
> of clustered markers.
> <br>
> - An icon for non-clustered markers and after a marker click a popup form
> showing the
> extracted attributes from the kml file (this is the default)
> <br>
> <br>
> I've already tried several examples, but no luck so far.
> <br>
> <br>
> Any help appreciated,
View this message in context: http://osgeo-org.1560.n6.nabble.com/Need-help-for-Cluster-strategy-using-externalGraphic-tp5037985p5038004.html
