[OpenLayers-Users] Problem Geoserver Layer
Gery .
gamejihou at hotmail.com
Mon Mar 4 12:31:01 PST 2013
perhaps you're declaring your extent in the wrong place, or you forgot to declare "map"?
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
Date: Mon, 4 Mar 2013 19:25:32 +0100
To: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Problem Geoserver Layer
El 03/03/13 20:51, Phil Scadden
escribió:
But
Firebug show me this error:
TypeError: a is null
http://localhost/arqueoserver3/OpenLayers-2.12/OpenLayers.js
Line 467
For debugging, change your script to be http://localhost/arqueoserver3/OpenLayers-2.12/lib/OpenLayers.js
It will then use an uncompressed version of openlayers and you
can see more clearly what is going wrong.
Notice:
This email and any attachments are confidential. If received
in error please destroy and immediately notify us. Do not copy
or disclose the contents.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Thanks a lot for your reply Phil,
i did what you suggested and I get this error:
TypeError: extent is null
http://localhost/arqueoserver3/OpenLayers-2.12/lib/OpenLayers/Layer/Grid.js
Line 967
I'm trying to set a extent, but it doesn't work neither... Do
somebody know what means this error?
Thanks a lot!
Luís Miguel Royo Pérez
Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130304/ef6a0b92/attachment.html>
