[OpenLayers-Users] Conversion of BBox for GetFeature Request
Arnd Wippermann
arnd.wippermann at web.de
Thu Mar 7 10:33:41 PST 2013
I have tried your selectClick declaration, but i doesn't work. But if I add
a line from
the selectBox declaration I use, it doses work.
Try with : this.setModifiers(...
Why this works, i really don't now. Perhaps without this, it causes an
error, and stops the rest.
selectClick: function(evt){
var bounds =
this.pixelToBounds(evt.xy).transform(this.map.getProjectionObject(), new
OpenLayers.Projection('EPSG:4326'));
this.setModifiers(this.handlers.box.dragHandler.evt);
this.request(bounds, {single: this.single});
You have to add something else to your code:
myControl.events.register("featureselected", this, function(e) {
e.feature.geometry.transform(new
OpenLayers.Projection('EPSG:4326'),this.map.getProjectionObject());
highlightLayer.addFeatures(e.feature);
because the request gets the feature not in the map projection. You have to
reproject it.
And last but perhaps not important, how I add my control (i use MapServer as
mapserver):
WFSfromWMSLayerOptions = {
version:"1.0.0",
geometryName: 'msgeometry',
maxFeatures: 100,
srsName:new OpenLayers.Projection('EPSG:4326'),
filterType: OpenLayers.Filter.Spatial.BBOX
control = new OpenLayers.Control.myGetFeature({
protocol: OpenLayers.Protocol.WFS.fromWMSLayer(lyr1,
WFSfromWMSLayerOptions),
box: true,
click: true,
single: false,
clickTolerance: 10
Good Luck,
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Jerome A.
Wendell
Gesendet: Donnerstag, 7. März 2013 02:55
An: 'Phil Scadden'; openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] Conversion of BBox for GetFeature Request
Phil,
Thanks. I will give that a try. I have not used the debug version before,
but I will set it up to use that.
-----Original Message-----
[mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Phil Scadden
Sent: Wednesday, March 06, 2013 8:41 PM
To: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Conversion of BBox for GetFeature Request
Use lib/Openlayers version (debug) so you can debug into OL source code, and
set breakpoint in the select: function in getfeatures.js Step through this
and see if it sheds any light.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Users mailing list
