[OpenLayers-Users] Outside of (-180, 180) error during saving Vector feature
杨华杰
yhjhoo at gmail.com
Fri Mar 8 22:19:08 PST 2013
Hi Guys
First of all , thanks for all the reply.
>From the error, everyone know it's because the coordinates exceed, and a
direct answer is converting the coordinate.
I want to know how, not the principal
On Sat, Mar 9, 2013 at 2:01 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
> Any code tips, I am new to openlayer and geoserver.
> Don't know what to do
> On Fri, Mar 1, 2013 at 11:21 AM, Phil Scadden <p.scadden at gns.cri.nz>wrote:
>> On 1/03/2013 4:08 p.m., 杨华杰 wrote:
>>> Thanks for all the replies, so I can solve it in Openlayer, any tips to
>>> change the projection?
>> It very much depends on your backend - the underlying spatial database
>> you are storing into (and will need to reproject out of). I think you will
>> need to just try and see what works. Sometimes we find that projection from
>> server to client will work for some projections but not others (notably
>> lat/longs stored as 0:360 on server). In utter desparation you can break
>> geometry on the 180 line but you lose polygon topology that way. We have a
>> ghastly trick that works for arcSDE in maintaining polygon topology over
>> the 180 (create it west of 180, lie about the coordinates, then translate
>> to correct position and force projection to the correct one) and works okay
>> with a tiled geoserver serving it back.
>> Notice: This email and any attachments are confidential.
>> If received in error please destroy and immediately notify us.
>> Do not copy or disclose the contents.
>> ______________________________**_________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130309/49f03dda/attachment.html>
