[OpenLayers-Users] Coordinates Reversed
Jerome A. Wendell
jawendell at digitalmapping.com
Mon Mar 11 17:52:24 PDT 2013
Tom,
Thanks for your reply. I am using WFS 1.1.0 and and GML 2. I am using
OpenLayers 2.12, and on the server I am using GeoServer 2.2.4. The WMS
layer that I am accessing is in shapefile format, and is in EPSG:4326. The
data, server, etc. are all ours. The original question that I had was when
the WMS layer is accessed using a select control, the features are returned
in GML format with the longitude first, and then the latitude. When the
same layer is accessed using a filter to select only features with a
specific attribute value, the features are returned in GML format with the
latitude first, and then the longitude. I am fairly new to OpenLayers and
GeoServer, so I presumed that I must be doing something wrong for the
coordinates of the same feature to be returned in reverse order. I will try
using WFS 1.0 and see what happens.
I appreciate the information.
Thanks.
-----Original Message-----
[mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Tom Kunicki
Sent: Monday, March 11, 2013 5:14 PM
To: undisclosed-recipients:
Cc: OpenLayers User List
Subject: Re: [OpenLayers-Users] Coordinates Reversed
To help it would be useful to know the WFS version and server-side vendor
and implementation you are attempting to utilize.
The easiest thing would be to use WFS 1.0 with GML2. You'll (usually) get
back geographic coordinates in [lon, lat]
The longer gist-of-it-but-skipping-details explanation:
There's some ambiguity as to what the axis ordering should be.
Computer-folk tend to prefer [x, y] or [lon, lat] and this was how the
computer-folk implemented these services for a long time. The reality is
that the authorities that define the coordinate systems (i.e. the "EPSG" in
"EPSG:4326") define the proper axis order for coordinates. As an example
for EPSG:4326 the authority defined axis order is [lat, lon] == [y, x] ==
[north, east]. The purists brought up this discrepancy and in 2009 the OGC
put forth this guidance note: http://www.ogcnetwork.net/node/491. What
this says that any specification generated after 2009 (and implementations
of those specifications) must respect the authority defined axis order (i.e.
[lat, long] not [lon, lat]). Now this is all muddled because vendors have
put forth varying degrees of compliance in the implementations of these
newer services. There a number of nuances to all of this and it's usually
easier (if possible) to use servi ces that pre-date the 2009 upheaval
(where everything was in the incorrect, but consistent axis order).
Tom
