[OpenLayers-Users] OpenLayers.Format.GPX read function, syntax to read 'ele' tags
digby
digbymaass at gmail.com
Fri Mar 29 08:23:09 PDT 2013
I'm thrashing around in the dark here, trying to read the 'ele' tags in a GPX
file. I can't find actual examples anywhere, or help with the API.
The map itself is quite successful for showing (and toggling) gpx tracks,
and displaying the lengths. See wed-slow-fast27mar.htm but I'd now like to
add the total ascents as well. How do you implement the read function?
var runslow = "../gpx/wed-slow-06feb13.gpx"
// read function for runslow here //
// then calculate the ascent:
var eles = runslow.getElementsByTagName("ele");
for (var i=0, len=eles.length; i<len; i++) {
if (eles[i] > eles[i-1])
ascent = ascent + (eles[i] - eles[i-1]);
View this message in context: http://osgeo-org.1560.n6.nabble.com/OpenLayers-Format-GPX-read-function-syntax-to-read-ele-tags-tp5043707.html
