[OpenLayers-Users] angualjs and openlayers map in div. Somethings not right...
brett at mak.com
brett at mak.com
Sat Mar 30 05:25:43 PDT 2013
Anyone using angular and openlayers? I've got a problem... when I put an
openlayers map in a div and use ng-style to position it, the map doesn't
quite understand where it is and gets all messed up. Here's a plunker that
shows my problem:
http://plnkr.co/edit/5qaMIV
The code should put a marker at a simulated mouse click position of 100,100
(which should be in mexico). If you replace the map div that uses ng-style
with the map div that just uses a hardcoded style you will see the correct
expected result.
What's happening when I use ng-style? Is it overwriting some of openlayers
style stuff that tells openlayers about where on the page the map is? (Btw,
I had to use ng-show in order to call map.updateSize() which should tell the
map to calculate its new position.
Thanks,
Brett
View this message in context: http://osgeo-org.1560.n6.nabble.com/angualjs-and-openlayers-map-in-div-Somethings-not-right-tp5043790.html
