[OpenLayers-Users] WFS Data Truncated [SOLVED]
Rob McCulley
RMcCulley at county24.com
Fri May 3 12:10:20 PDT 2013
I tried OL's 2.10, 2.11, and 2.12 with the same results. Finally I looked at recompiling Mapserver for GeoJson output. After the recompile, everything worked using GML format, so it appears that Mapserver was my problem, despite the fact that it worked as expected in QGIS and in the browser. The only thing I can think of that would account for this is perhaps QGIS, like the browser is using GET requests, while OL uses a POST request.
Anyways, thanks for the help.
Rob
Sent: May-03-13 2:16 AM
To: Rob McCulley; openlayers-users at lists.osgeo.org
Subject: RE: [OpenLayers-Users] WFS Data Truncated
Perhaps Rob you need to try older versions of OL to see if it is the problem, I work with 2.11 and all the things I have tried work great. Here it's an old discussion about geojson and mapserver if you're interested: http://lists.osgeo.org/pipermail/mapserver-users/2009-July/061955.html.
Hope this helps,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
> From: RMcCulley at county24.com<mailto:RMcCulley at county24.com>
> To: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>; openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
> Date: Thu, 2 May 2013 15:56:13 -0600
> I'm on windows 7. My mapserver install is working perfectly. I can view all of the WFS data in qgis. I get valid and complete XML output if I do a GetFeature request in a browser. The only time my WFS output is truncated is in OpenLayers.
> I tried to output in GeoJson, but apparently my mapserver setup cannot output GeoJson. I'm not sure if it is not compiled for it, or if it is in my mapfile setup. It shouldn't matter though, because the GML based WFS output works everywhere but OpenLayers.
> Thanks,
> Rob
> -----Original Message-----
> From: Gery . [mailto:gamejihou at hotmail.com]
> Sent: May-02-13 2:57 PM
> To: Rob McCulley
> Cc: openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
> Subject: Re: [OpenLayers-Users] WFS Data Truncated
> Hi Rob,
> Are you in Linux? It seems to me that it should be only mapserv? instead of mapserv.exe? Also, how about using GeoJson instead of XML?
> Gery
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130503/90516c98/attachment.html>
