[OpenLayers-Users] How to display WFS layer from MapServer?
Robert Sanson
Robert.Sanson at asurequality.com
Thu May 16 14:21:43 PDT 2013
Is it a proxy issue? Do you need to add myServer address to your proxy?
Regards,
Robert
>>> Luís de Sousa<luis.a.de.sousa at gmail.com> 17/05/2013 3:10 a.m. >>>
Dear all,
I have MapServer serving a simple polygon layer defined in this way:
LAYER
NAME "buildings_gml"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "/var/sampleData/BuildingsFull.gml"
STATUS ON
DUMP TRUE
PROJECTION
"init=epsg:28992"
END
METADATA
"ows_title" "Building footprints"
"ows_abstract" "Data set of building footprints"
"gml_include_items" "all"
"ows_featureid" "cat"
END
CLASS
NAME "building_footprints"
OUTLINECOLOR 255 0 0
END
END
I can access this layer with QGis using both the WFS and WMS protocols.
I'd
like to display it as a WFS layer in an OL map; I'm using this set up:
buildsWFS = new OpenLayers.Layer.Vector("BuildingsWFS", {
strategies: [new OpenLayers.Strategy.Fixed()],
projection: new OpenLayers.Projection("EPSG:28992"),
protocol: new OpenLayers.Protocol.WFS({
url:
"http://myServer/cgi-bin/mapserv?map=/var/www/MapFiles/test.map",
featureType: "buildings_gml",
featureNS: "http://mapserver.gis.umn.edu/mapserver"
srsName: "EPSG:28992",
When I add this layer to the map object I don't get any JS errors back
but
no requests are issued to the server and hence nothing shows up in the
map.
Using a WMS layer object I can display this layer without issue, using
this
set up:
buildsWMS = new OpenLayers.Layer.WMS(
"BuildingsWMS",
{layers: "buildings_gml",
format: "image/png",
transparent: "true",
projection: new OpenLayers.Projection("EPSG:28992")},
{isBaseLayer: false,
visibility: true}
I understand that displaying WFS layers from MapServer poses regular
difficulties, but even after going through several threads [1,2,3,4]
with
similar problems I still can't find what is wrong in my case.
Any help appreciated, Thank you,
Luís
[1]
http://lists.osgeo.org/pipermail/openlayers-users/2011-May/thread.html#20574
[2]
http://gis.stackexchange.com/questions/57545/why-is-mapserver-layer-not-showing-up-in-openlayers
[3]
http://stackoverflow.com/questions/14477019/wfs-mapserver-layer-not-showing-up-in-openlayers
[4]
http://gis.stackexchange.com/questions/26627/set-up-wfs-service-on-mapserver-and-display-in-openlayers
View this message in context:
http://osgeo-org.1560.x6.nabble.com/How-to-display-WFS-layer-from-MapServer-tp5053728.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
