[OpenLayers-Users] WMSgetFeatureInfo ProxyHost
Phil Scadden
p.scadden at gns.cri.nz
Tue May 21 14:15:55 PDT 2013
What happens if you try the same call directly in the browser (right
click on the call in the NET tab of fire bug and choose "open in new
tab"? (or just the URL direct into browser bar). You want to compare the
call via the proxy with the call made direct. You dont have browser
security in the way doing this. If it is POST data rather than GET, then
try with CURL or with this rather nifty free tool
http://code.google.com/p/rest-client/ (I use this constantly).
If it works to remoteIP when going direct but returns 401 (or whatever
the proxy is set to on fail) when going through proxy, then proxy is
misconfigured. If direct call fails, then problem must lie with security
at geoserver end or with firewall rules.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
