[OpenLayers-Users] EPSG:4326 WMS map aspect ratio
Smart, Gary Gary.Smart at utas.utc.com
Wed May 22 06:59:22 PDT 2013
I really would like to display the contents of my local WMS in a form
which the users are used to (i.e. square OS grids, rather than the
'squashed' appearance which comes from mapping the EPSG:4326 onto a
flat-Earth projection in high latitudes).  I have found numerous
examples of' how to resolve this problem', but none seem to have any
effect on the distortion OR they result in no map being displayed at
all.  I cannot connect directly to map servers on the web (spherical
Mercator), because my system is an isolated network and the maps are
supplied by the customer.
Salient extracts from the js code follow:
        var map, options = {
                             projection: new
OpenLayers.Projection('EPSG:4326'),
                             //displayProjection: new
OpenLayers.Projection('EPSG:3574'),
                             //units: 'm',
                             //maxResolution: 156543.0339,
                             //maxExtent: new
OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508)
                             zoom: 14
        map = new OpenLayers.Map('map', options);
        var my50kLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://expdev2/cgi-bin/wms?",
                                                     layers:
'UK_ASRP_1to50000',
                                                     format:
'image/png',
                                                     //transparent:
'true',
                                                    continuousWorld:
true,
                                                     attribution: "OS
1:50K",
        map.addLayers([my50kLayer]);
As the code exists above, the displayed map works fine (apart from the
squished grid rectangles).  Having adapted the 'measure example' from
the OpenLayers examples page, I can measure from the map, and if the
geodesic selection is made, the measurements are clearly correct (1Km
across both dimensions of the OS grid).  With geodesic selection not
clicked, the measurement across the map is approximately 1.5Km.  So the
transforms and projections are clearly in sync.  But how do I stretch
the maps in the 'y' direction so they appear equant (not squished
vertically)?
Adding the displayProjection seems to do nothing.  Using any of the
other options with my WMS, results in a blank map.
I have also plagiarised the polar-projections example from the
OpenLayers example site, and replace the buttons with the following
projections:
var projectionOptions =
        'EPSG:4326':
            projection: new OpenLayers.Projection('EPSG:4326')
        'EPSG:3857':
            projection: new OpenLayers.Projection('EPSG:3857'),
            maxExtent: new OpenLayers.Bounds(-5505054, -5505054,
5505054, 5505054),
            maxResolution: 5505054 / 128,
            numZoomLevels: 18
    }; // end projectionOptions array
And I have applied the projections as per the example code (i.e.
setProjection function was copied and is being called).  However,
pressing EPSG:3857 button results in a blank map, and pressing EPSG:4326
after that, also results in a blank map (albeit with a white pair of
tiles in the middle)!
Can anyone tell me whether it is possible to display a square grid for
OS maps coming from an EPSG:4326 WMS?
Thank you.
Gary Smart PhD - Software Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
Malvern Hills Science Park, Geraldine Road, Malvern, WR14 3SZ
Tel: (+44) 1684 899783
gary.smart at utas.utc.com <mailto:gary.smart at utas.utc.com>
www.utcaerospacesystems.com <http://www.utcaerospacesystems.com/>
CONFIDENTIALITY WARNING: This message may contain proprietary and/or
privileged information of UTC Aerospace Systems and its affiliated
companies. If you are not the intended recipient please 1) do not
disclose, copy, distribute or use this message or its contents, 2)
advise the sender by return e-mail, and 3) delete all copies (including
all attachments) from your computer. Your co-operation is greatly
appreciated.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130522/d36de1de/attachment-0001.html>
