[OpenLayers-Users] How to Rotate an image
Arnd Wippermann arnd.wippermann at web.de
Thu Nov 14 13:39:01 PST 2013
Hi Josep,
I have forgotten, that you have to apply a context to the stylemap to
display the externalGraphic in map units.
Otherwise has the symbolizer used to display a point feature allways the
same size in every zoom level.
Example:
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL212/externalGraphicRotation.asp
Regards,
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Josep
Sanmartí
Gesendet: Donnerstag, 14. November 2013 13:26
An: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] How to Rotate an image
Thanks Arnd,
It works! But since I've applied your solution I can't zoom in nor out the
image. Well, in fact it zooms but immediately it returns to the default
display
Here it is: http://jsfiddle.net/gilan/2CK25/
On 11/13/2013 06:16 PM, Arnd Wippermann wrote:
> Hi,
> You have to add a point feature to your vector layer, to which the
> style will applied and declare a baselayer:
>      vectorLayer.isBaseLayer=true; //or allOverlays:true in the map
> object
>      map = new OpenLayers.Map( 'map', {
>          //allOverlays:true,
>          controls: [
>              new OpenLayers.Control.PanZoom(),
>              panel]
>      var geometry = OpenLayers.Geometry.fromWKT("POINT(0 0)");
>      var feature = new OpenLayers.Feature.Vector(geometry);
>      vectorLayer.addFeatures([feature]);
>      map.addLayers([vectorLayer]);
> Arnd
> Sanmartí
> Gesendet: Mittwoch, 13. November 2013 12:04
> Betreff: [OpenLayers-Users] How to Rotate an image
> Hello all,
> Once added an image and a custom button, I'm interested about how to
> rotate the image. I've read that an image can't be rotated unless is
> defined as a vector. I've created a vector with the image but nothing
> is
> displayed: http://jsfiddle.net/gilan/2CK25/
> Can anybody help me with this issue?
> Thanks in advance!
> Josep Sanmartí Besora
> Consorci de Biblioteques Universitàries de Catalunya -
> http://www.cbuc.cat/
> Telf.: 93 567 98 07
> Fax:  93 205 01 50
> Correu: jsanmarti at cbuc.cat
> El Consorci de Biblioteques Universitàries de Catalunya li agrairà que
> si ha rebut aquest correu electrònic sense ser la persona a qui es
> volia destinar, ens el reenviï i suprimeixi ambdós missatges i, si és
> el cas, els fitxers que pogués portar com a annex. Qualsevol altre ús
> o acció podria ser contrària a la llei. Gràcies.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Consorci de Biblioteques Universitàries de Catalunya - http://www.cbuc.cat/
Telf.: 93 567 98 07
Fax:  93 205 01 50
El Consorci de Biblioteques Universitàries de Catalunya li agrairà que si ha
rebut aquest correu electrònic sense ser la persona a qui es volia destinar,
ens el reenviï i suprimeixi ambdós missatges i, si és el cas, els fitxers
que pogués portar com a annex. Qualsevol altre ús o acció podria ser
Users mailing list
