[OpenLayers-Users] Esri ArcServer 10.2 WMS 1.3.0 not working
PoconoMapper
bill at gistechsolutions.com
Wed Nov 27 17:18:19 PST 2013
<ServiceException code="LayerNotDefined">
Parameter 'layers' contains unacceptable layer names.
</ServiceException>
I was putting Layer Title values not Name values for Layers.. Thanks for
the hint, it was an easy fix once you told me where to look.
[mailto:ml-node+s1560n5091575h33 at n6.nabble.com]
Sent: Wednesday, November 27, 2013 5:03 PM
To: PoconoMapper
Subject: Re: Esri ArcServer 10.2 WMS 1.3.0 not working
Using the NET tab in firebug or chrome developer tool, look at the URL
generated by creating the map.
Firstly, the response (if any) might give you some clues. Otherwise try
copying the URL (in firebug that is right-click, copy location off the
call in the net tab) directly into a browser and see what happens. I am
guessing you getting a malformed URL which should give you some clues.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Users mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/openlayers-users
_____
If you reply to this email, your message will be added to the discussion
below:
<http://osgeo-org.1560.x6.nabble.com/Esri-ArcServer-10-2-WMS-1-3-0-not-worki
ng-tp5091574p5091575.html>
http://osgeo-org.1560.x6.nabble.com/Esri-ArcServer-10-2-WMS-1-3-0-not-workin
To unsubscribe from Esri ArcServer 10.2 WMS 1.3.0 not working,
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscr
ibe_by_code&node=5091574&code=YmlsbEBnaXN0ZWNoc29sdXRpb25zLmNvbXw1MDkxNTc0fC
0xNjkwMTY5ODkx> click here.
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_vi
ewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.Basic
Namespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.
NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_e
mails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Esri-ArcServer-10-2-WMS-1-3-0-not-working-tp5091574p5091581.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20131127/ea30791e/attachment.html>
