[OpenLayers-Users] ExtJS 4 Class system and Openlayers
Bart van den Eijnden
bartvde at boundlessgeo.com
Wed Oct 9 05:06:00 PDT 2013
I'd check out the GeoExt2 code base for some ideas if I was you.
https://github.com/geoext/geoext2
Best regards,
Bart
Front-end Developer | Boundless
@boundlessgeo
On Oct 9, 2013, at 1:14 PM, svranic.gf <svranic at geof.hr> wrote:
> Hi everyone,
> I am having problems with integrating Openlayers and ExtJS 4. I had no
> problems with embeding map within ExtJS panel. I have troubles with
> following features:
> Feature info - I can catch map click and I get based on the coordinates data
> in json format. Store, model and grid are configured correctly because it
> works on a local json file. On a map click store should be reloaded. It
> should probably be reloaded from click handler defined in a file where I
> defined OL app and click event but I don't know how because of new class
> system of ExtJS 4, i.e. how should I reference store and how should I call
> .load() method
> Tree panel - layer swithcher - with this one problem is following: Firebug
> first reported that it cannot see variables layer1, layer2 and layer3. I
> defined as global in my olApp.js file. Next, error occured that stated:
> method setVisibility() is not defined. Question: How can I call any method
> defined in Openlayers from ExtJS when using MVC architecture with new ExtJS
> 4 class system?
> Ext.define('app.view.LayerSwitcherTreePanel', {
> extend: 'Ext.tree.Panel',
> alias: 'widget.layerSwitcherTreePanel',
> title: 'Layers',
> listeners: {
> checkchange: function(node, check) {
> if (node.get('id') == 'layer1') {
> layer1.setVisibility(true);
> layer2.setVisibility(false);
> layer3.setVisibility(false);
> } else if (node.get('id') == 'layer2') {
> layer1.setVisibility(false);
> layer2.setVisibility(true);
> } else if (node.get('id') == 'layer3') {
> layer3.setVisibility(true);
> root: {
> text:'All layers',
> expanded:true,
> children:[{
> text: 'Layer set 1',
> expanded: true,
> children: [{
> text: 'Layer 1',
> leaf: true,
> checked: true
> text: 'Layer 2',
> leaf: true,
> checked: false
> text: 'Layer 3',
> leaf: true,
> checked: false
> text:'Layer set 2',
> expanded: true,
> children:[{
> text:'Layer xyz',
> leaf:true,
> checked: true
> To summarize, I have a feeling that only problem with my application is
> visibility of method and variables accross two JS frameworks.
> I hope that everything I wrote is more or less clear. If not or if
> additional code is required please let me know.
> Cheers
> Sasa
> View this message in context: http://osgeo-org.1560.x6.nabble.com/ExtJS-4-Class-system-and-Openlayers-tp5082576.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20131009/b0015e13/attachment-0001.html>
