[OpenLayers-Users] Pinch-Zoom / Drag while having an active clickControl
Frederick Löbig frederick.loebig at live.de
Mon Apr 14 06:36:43 PDT 2014
Hi all,
I have a small problem which I think can be solved pretty quickly.
The map I have as multiple different "clickControls", which, depending on which one is activated, lead to several different actions. One of these controls is a simple clickFeature, to show a detail window of the selected vector feature (added via a GML file). I now want to use pinch zoom and simple map dragging without selecting a feature each time I touch the map. So basically, what I want to achieve is, to drag and zoom the map in any case, even if I hold down on a feature. This is my code for the selectFeature control:
			clickFeature = new OpenLayers.Control.SelectFeature(			   [pointLayer],			   {				   clickout: true, toggle: false,				   multiple: false, hover: false,			   }			);										map.addControl(clickFeature);								pointLayer.events.on({				   "featureselected": function(e) {						//drag.activate();                                                //openDetail(e.feature.attributes.Id);												ajax_request('mob_detail.php','POST','?t=1&id='+e.feature.attributes.Id,'mob_detailLayer');                                                closeToolTip();						//dumpProps(e.feature.attributes);                                                //document.getElementById("debug").value=e.feature.attributes.Id;				   },				   "featureunselected": function(e) {						closeDetail();				   }			   });			   						clickFeature.activate();
This is the link to the current application: www.linie11.org/mapApp/go_map.php Any ideas? Thanks in advance! It's driving me crazy right now...
Cheers,Freddy
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140414/81d0c0d9/attachment.html>
