[OpenLayers-Users] How control openlayers local caching of tiles?
Uggla Henrik Henrik.Uggla at kristianstad.se
Thu Aug 21 06:27:11 PDT 2014
Hi!
Openlayers seems to cache tiled WMS layers (but not single tile) locally in the browser. I need to be able to clear the cache when a user clicks a button but haven't managed to find out how to do it. In Firebug I can see the browser loading the tiles from the source the first time but when loaded a second time it doesn't send a request at all but loads the tiles from some sort of local cache. Even when all caching is disabled in Firefox tiles are still cached locally. The only way to clear the cache is to reload the whole page with ctrl+F5 (only F5 doesn't work). Using php to destroy the session doesn't work either. I've also tried to add a TileManager for the map but it doesn't seem to be active and clearing it does nothing. Then I've tried the CacheWrite control, executing clearCache. Once again, no effect. I've also tried to set html headers cache-control, pragma etc. but the tiles are still cached. Can someone please explain how to control that cache?
Regards
Henrik
