[OpenLayers-Users] Image reload attempts possibly ignored
Andreas Hocevar
andreas.hocevar at gmail.com
Wed Dec 3 12:58:35 PST 2014
Hey Andrea,
a lot has changed in image loading since 2.11. But regardless, the issue you are seeing can mean that only the first attempt caused image loading to fail with a load error (whatever that means to the browser, we cannot control that), and that the second did not trigger an error.
If you can point to a reproducible live example, I'll take a closer look. Also trying 2.13 instead of 2.11 might be a good idea.
Andreas.
Sent from my iPhone
> On 02 Dec 2014, at 20:10, Andrea Aime <andrea.aime at geo-solutions.it> wrote:
> Hi,
> I'm looking at some white tiles in the GeoServer preview, happening randomly,
> which I've noticed are happening somehow randomly, without error logs
> in GeoServer.
> Then I made a guess and enabled the logging of http connection closed in the GeoServer
> face by the client, and sure enough, two white tiles in the map, two errors (and just
> two) that the client closed the HTTP connection before GeoServer could write out
> the response.
> The response is coming back in less than a second, and the preview has:
> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 5;
> So, I was sort of expecting to see 10 errors in the GeoServer log, for those two
> missing tiles, not just two...
> Any chance the reload attempts are not working as they should?
> I'm on Chrome 39, Linux Mint, OpenLayers 2.11
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Please, notice that GeoSolutions will be closed for seasonal holidays
> from December the 24th to January the 6th
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20141203/c2ce8e19/attachment.html>
