[OpenLayers-Users] Removing features from a cluster
Rob Hyx
robhyx at gmail.com
Thu Jan 16 11:56:17 PST 2014
Thanks Xavier, I will take a look at that.
Another question about clustering: Can you continuously add features to a
clustered layer and have it re-cluster each time a new feature is added?
I'm having an issue where it's just replacing the previous feature with the
new one and I'm wondering if it's something I'm doing.
Thanks in advance!
On Wed, Jan 15, 2014 at 1:15 PM, Xavier Mamano (jorix) <
xavier.mamano at gmail.com> wrote:
> Hi,
> This is not supported by the OL standard. Some time ago I wrote some code
> to
> adjust issues in Cluster strategy, I think this problem is also solved in
> my
> code.
> Try use:
> https://github.com/jorix/OL-Ragbag/blob/gh-pages/lib/Ragbag/Strategy/CenteredCluster.js
> See example:
> http://jorix.github.io/OL-Ragbag/examples/strategy-centered-cluster-add-remove.html
> This example allows dynamically add points, and enable/disable the Cluster
> strategy. But only deletes the entire cluster (while strategy is enabled),
> otherwise it should work with the js (while Cluster strategy is active in
> the layer are clusters that contains a array of features --named cluster--)
> > but it seems the strategy itself keeps a cache of the features.
> Yes, named teatures. In this aspect disable cluster works differently than
> OL staqndad code, the features of the layer are restored.
> Xavier
> dnbphysicist wrote
> > Hello all, I've done some searching on Google of this, but haven't found
> a
> > good way to accomplish it yet. I have a map that allows other
> applications
> > to add and remove layers and features from it dynamically. If a vector
> > layer is clustered and another application goes to delete one or more of
> > the features in the cluster, obviously the remove features function is
> not
> > going to work. Is there a good way to do this? I tried iterating over all
> > of the clusters, and then the features in that cluster but it seems the
> > strategy itself keeps a cache of the features. I also tried deactivating
> > the strategy, but it seems that just causes the layer to retain the
> > clusters as features and no longer expands or contracts with zoom ins and
> > outs (not surprisingly). Any help would be greatly appreciated.
> > Thanks in advance!
> > Users mailing list
> > Users at .osgeo
> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> http://osgeo-org.1560.x6.nabble.com/Removing-features-from-a-cluster-tp5098224p5098245.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
*HYX*
http://hyx-music.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140116/e956adec/attachment.html>
