[OpenLayers-Users] How do I draw a box, retreive map coordinates, and pass to a python function?
William Hudspeth
bhudspeth at edac.unm.edu
Wed Jul 23 07:28:55 PDT 2014
Thanks much Phil....I will take a look and see if I can adapt your code....
Vick
On 07/22/2014 04:00 PM, Phil Scadden wrote:
> okay, here is some outline (what I do for searching). Overview:
> Create a vector layer (selectedLayer) in which drawing occurs.
> Use a drawfeature control to do the drawing.
> When feature added to to drawcontrol, extract the geometry, call
> server with a callback to handle the response.
> the code:
> selectedLayer = new OpenLayers.Layer.Vector("Selected Layer", {
> wrapDateLine: true,
> displayOutsideMaxExtent: true,
> displayInLayerSwitcher: false,
> map.addLayer(selectedLayer); (top layer)
> ctrl= new OpenLayers.Control.DrawFeature(selectedLayer,
> OpenLayers.Handler.Polygon, {
> geodesic: true, // stuff for managing drawing across
> 180 line
> handlerOptions: {
> citeCompliant: false
> // you can use different handler other than polygon for other geometries
> ctrl.events.register("featureadded", this, function (e) {
> Ext.Ajax.request({ // i am using Ext, but you can use any
> ajax wrapper you like
> url:'mypythoncode',
> method:'GET',
> success:function(response){
> // process the response
> params:{
> geometry:serialize(e.feature.geometry) // you need to
> write serialize to your taste to format the geometry
> id: new Date().getTime(); // avoid browser caching
> That should get you started.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
