[OpenLayers-Users] POST not implemented
Phil Scadden
p.scadden at gns.cri.nz
Tue Jul 29 21:46:22 PDT 2014
> I'm using the OpenGeo suite with GeoExplorer as client. In the file
> composer.html is setting proxy: "../proxy/?url=" and works well. I
> can also make DescribeProcess queries using GET method but when I do
> an EXECUTE request using POST method is not working.
> if I change proxy settings to some of these /proxy/proxy.cgi?url=xxxx
> or /proxy.cgi?url=xxxx stop operating the query using GET DescribeProcess.
Sorry, I dont know the OpenGeo suite or Geoexplorer, it might best to
take it up with them.
GET doesnt use the proxy - doesnt need to. You need the proxy to deal
with cross-origin security issues when using XHR. (ajax). if
ProxyHost="/proxy..." this implies you have a /proxy context on the
server. "../proxy" looks more likely - but /proxy/?url doesnt look like
a valid syntax. Is there a proxy directory or script at the same level
as your main html on the server?
The important thing is to look at your server set up. See where the
proxy code actually is, what it is, and then make sure the client
matches it. It is common to use cgi with Apache but I know next to
nothing about this as deploy with tomcat and use a jsp for proxy.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140730/201b2dec/attachment.html>
