[OpenLayers-Users] CascadedPolygonUnion using JSTS in OpenLayers
rickm81 rickm81 at yahoo.com
Wed Jun 18 07:50:35 PDT 2014
Hello,
I'm using the JavaScript Topology Suite to union polygons in OpenLayers.
Everything works fine if I iterate through polygons in vector layer.
However, I believe I could improve performance with the CascadedPolygonUnion
function.
Is there an example of CascadePolygonUnion using geometries parsed from
OpenLayers? Below is an example of the method I am currently using. Thank
you!
var vLayer = new OpenLayers.Layer.Vector("Polygons", { styleMap: new
OpenLayers.StyleMap({ fillOpacity: 0.4, fillColor: "#FF0000", strokeColor:
"#FF0000"}) });
var mLayer = new OpenLayers.Layer.Vector("Merged Polygons", { styleMap: new
"#FF0000"}) });
var jsts_parser = new jsts.io.OpenLayersParser();
var fts = vLayer.features;
    for (var q = 0; q < fts.length; q++) {
        if (q == 0) {
            var jsts_geomA = jsts_parser.read(fts[q].geometry);
        else {
            var jsts_geomB = jsts_parser.read(fts[q].geometry);
            jsts_result_geom = jsts_geomA.union(jsts_geomB);
    var ol_geom = jsts_parser.write(jsts_result_geom);
    var ol_ft = new OpenLayers.Feature.Vector(ol_geom);
    mLayer.addFeatures(ol_ft);
View this message in context: http://osgeo-org.1560.x6.nabble.com/CascadedPolygonUnion-using-JSTS-in-OpenLayers-tp5146545.html
