[OpenLayers-Users] feature doesn't change color on click?!
zach cruise zachc1980 at gmail.com
Thu Jun 19 06:24:54 PDT 2014
to clarify:
style works as expected on feature 'over', but doesn't change on
feature 'click'.
i've set "default", "temporary" and "select" styles in StyleMap. they
are then fed to the layer. i didn't set any event listeners for
"featureclick". i am using "SelectFeature" and callbacks within.
oddly, style changes on feature 'select' but the function is not triggered:
"...callbacks: {'select': function_to_update_attribute_info }..."
what are the different options available under "callbacks" other than
'over' and 'click' and maybe 'select'? is there a help doc listing
them?
posting on stackexchange too.
On Wed, Jun 18, 2014 at 4:55 PM, zach cruise <zachc1980 at gmail.com> wrote:
> for wfs/gml layer:
> when i use "...callbacks: { 'over': function }...", the feature
> changes color on click as expected.
> but when i use "...callbacks: { 'click': function }...", the feature
> does not change color on click.
> and using the layer's StyleMap({"select":...}) does not help either.
