[OpenLayers-Users] Icon in my map using his natural size
pvrsouza
pvrsouza at gmail.com
Tue Mar 25 14:32:57 PDT 2014
Arnd,
Thanks for your reply..
I tried something like that, but in this case the img object just has its
width attribute after a load function. See the comment, plesae.
var context = {
getGraphic : function (ft){
var graphicUrl = "./" + ft.attributes["icon"];
return graphicUrl;
getGraphicW : function (ft){
var toReturn;
var img = new Image();
img.onload = function() {
toReturn = this.width; // At this point I was unable to pass the
method's return to getGraphicW function.
img.src = "./" + ft.attributes["icon"];
return toReturn; //at this point toReturn is empty. :-(
getGraphicH : function (ft){
return img.height;
2014-03-25 18:05 GMT-03:00 Arnd Wippermann [via OSGeo.org] <
ml-node+s1560n5131079h65 at n6.nabble.com>:
> You can try to get width an height with new Image()
> var styleMapIcon;
> var context = {
> return graphicUrl;
> return img.width;
> return img.height;
> var templateDefault = {
> fillOpacity: 0.5,
> pointerEvents: "visiblePainted",
> externalGraphic:"${getGraphic}",
> graphicWidth:"${getGraphicW}",
> graphicHeight:"${getGraphicH}"
> var templateSelect = {
> fillOpacity: 1,
> pointRadius: 60,
> graphicWidth:null,
> graphicHeight:null
> styleMapIcon = new OpenLayers.StyleMap( {
> "default" : new OpenLayers.Style(templateDefault,
> {context:context}),
> "select" : new OpenLayers.Style(templateSelect,
> {context:context})
> return(styleMapIcon);
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: [hidden email] <http://user/SendEmail.jtp?type=node&node=5131079&i=0>
> [mailto:[hidden email]<http://user/SendEmail.jtp?type=node&node=5131079&i=1>]
> Im Auftrag von pvrsouza
> Gesendet: Dienstag, 25. März 2014 11:33
> An: [hidden email] <http://user/SendEmail.jtp?type=node&node=5131079&i=2>
> Betreff: [OpenLayers-Users] Icon in my map using his natural size
> Hello everybody,
> It's my first time here and I didn't find any topic like this one here.
> Then
> here we go:
> I'd like to show the Icon in my map using his natural size (width and
> height
> original). How can i do it?
> Now i have this code:
> var contextResource =
> getWidthIcon : function(feature){
> //i'm trying to get the current width
> getHeightIcon : function(feature){
> //i'm trying to get the current height
> getMarker : function(feature)
> // getting the icon with a rest reponse
> var lstIcons = feature.attributes.satellites;
> var sUrlIcon =
> "${sBaseURL}/AvlCore/rest/icon/resource/composed/"+
> feature.attributes.orientation;
> for ( var n = 0; n < lstIcons.length; n++) {
> sUrlIcon = sUrlIcon + "/" + lstIcons[n];
> return sUrlIcon;
> getBackgroundMarker : function(feature)
> ///blah blah blah
> return urlBackground;
> getVisibility : function(feature)
> ///blah blah blah
> getLabel : function(feature)
> ///blah blah blah
> //This is my style builder
> var resourceStyle = new OpenLayers.Style({
> externalGraphic : '<% out.print("${getMarker}"); %>',
> backgroundGraphic : '<% out.print("${getBackgroundMarker}"); %>',
> graphicOpacity: 1,
> graphicWidth: '<% out.print("${getWidthIcon}"); %>',
> graphicHeight:'<% out.print("${getHeightIcon}"); %>',
> label: '<% out.print("${getLabel}"); %>',
> fontFamily: "Arial",
> fontSize: '11px',
> labelYOffset: -30,
> labelOutlineColor: "white",
> labelOutlineWidth: 3,
> display: '<% out.print("${getVisibility}"); %>'
> }, { context: contextResource });
> If I put a fixed graphicWidth and graphicHeight works normally. I want to
> display icons in different sizes. Is it possible using this strategy?
> Thanks
> http://osgeo-org.1560.x6.nabble.com/Icon-in-my-map-using-his-natural-size-tp
> 5130893.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5131079&i=3>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5131079&i=4>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Icon-in-my-map-using-his-natural-size-tp5130893p5131079.html
> To unsubscribe from Icon in my map using his natural size, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5130893&code=cHZyc291emFAZ21haWwuY29tfDUxMzA4OTN8MjEyOTgwODc5MQ==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Atenciosamente,
Pablo Souza
Twitter: @pvrsouza
Tel.: (71) 9983-7775
View this message in context: http://osgeo-org.1560.x6.nabble.com/Icon-in-my-map-using-his-natural-size-tp5130893p5131083.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140325/7d0c90a7/attachment.html>
