[OpenLayers-Users] Combo Box for layers
Robert Sanson
Robert.Sanson at asurequality.com
Sun May 25 14:50:30 PDT 2014
Hi Todd
Suppose you have some HTML for the combo box:
<p><select name="Layer" id="layer">
<option value="layer1">Layer 1</option>
<option value="layer2">Layer 2</option>
<option value="layer3">Layer 3</option>
</select>
Then you have a Javascript function:
function showoverlay() {
var overl = document.getElementById('layer').value;
if overl == layer1 {
l1.setVisibility(true);
l2.setVisibility(false);
l3.setVisibility(false);
else if overl == layer2 {
l1.setVisibility(false);
l2.setVisibility(true);
else if overl == layer3 {
l3.setVisibility(true);
where l1, l2, l3 are the overlay layers that have been added to the map.
Regards,
Robert
>>> Todd Fagin <tfagin at coordinatesolutions.com> 23/05/2014 7:41 a.m. >>>
Greetings OpenLayer users,
I have what I assume is a fairly simple question, one that has likely been
addressed previously. However, I have been unable to find the solution
online. To add insult to injury, I am not a programmer. I can look at
existing code and often modify it to my needs, but if I start with a blank
slate, I usually end with a blank slate.
So, here is my problem in a nutshell:
I have a simple OpenLayers application that displays WMS layers from
GeoServer plus several base layers (Google, Bing, etc.). Currently, it is
configured with the standard LayerSwitcher. However, I would like to have a
combo box from which users can select the overlay to display. It would be
nice to have a default overlay set, then users could select from the
dropdown list which overlay to display (for my purpose at hand, it is not
necessary to display more than one overlay at a time-at least the overlays I
wish to include in the combo box).
Surely (I assume), this is something many individuals have done before.
Keep in mind what I said above: I am not a programmer. So, if someone has
some sample code I could cannibalize, I will be forever in your debt (well,
maybe not forever, but.)
Many thanks in advance,
Todd
Todd Fagin
Coordinate Solutions, Inc.
2804 NW 18th St.
Oklahoma City, OK 73107
405.740.4324
www.coordinatesolutions.com
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
