[OpenLayers-Users] GetFeaturInfo call failing in IE11
Bart van den Eijnden bartvde at boundlessgeo.com
Thu Nov 20 05:32:13 PST 2014
Please note that this was fixed in master.
Best regards,
Bart
Front End Software Engineer | Boundless
1-877-673-6436
@boundlessgeo
On 20 Nov 2014, at 14:09, Ralph Dell <RDell at CatawbaCountyNC.gov> wrote:
> I believe this post may help
> http://osgeo-org.1560.x6.nabble.com/WFS-and-IE-11-td5090636.html
> I have taken the code written by Stephen Battey at the bottom of the post and load that after I load OL.
> That fixed my GetFeatureInfo problem on IE11
> Ralph Dell
> From: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Staav Per-Anders
> Sent: Thursday, November 20, 2014 3:31 AM
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] GetFeaturInfo call failing in IE11
> I am new to this mailing list, but we have been using OpenLayers for a while.
> Currently I am struggling with a problem with GetFeatureInfo and IE11 and I decided to share my experiences to hopefully help some other poor fellow to have to do the same analysis.
> I am using 2.13.1 of OpenLayers and GeoServer 2.4 and have applied a couple of fixes to get it to work in IE11 for WFS calls and similar. Unfortunately I cannot sort out the GetFeatureInfo calls.
> If I IE11 in Edge mode the call to OpenLayers.Format.XML.prototype.read.apply(this, [data]); eventually resolve into xmldom.loadXML(text) call failing and then  a failed call to new DOMParser().parseFromString(text, 'text/xml')
> If I use IE11 and emulate previous versions (aka Quirks mode) the call to loadXML succeed even through I used the debugger to verify that in both cases the actual text sent into the function is JSON
> "{\"type\":\"FeatureCollection\",\"features\":[{\"type\":\"Feature\",\"id\":\"LVD_FUNCTION_OBJECT_VIEW.3010124\",\"geometry\":{\"type\":\"LineString\",\"coordinates\":[[154111.811179288,6578422.01790236,0],[154111.295167272,6578428.93449788,0],[154112.323003077,6578434.88642851,0],[154119.436625185,6578454.94173547,0],[154127.927454092,6578478.22225933,0],[154130.750467693,6578486.2847629,0],[154131.816409608,6578490.96371858,0],[154130.856751895,6578508.97999902,0]]},\"geometry_name\":\"GEOLOC\",\"properties\":{\"FUNCTION_OBJECT_NO\":9112,\"FUNCTION_OBJECT_NAME\":\"Västra Terrassrampen (1) (Norra Järngraven - Katarinavägen) (050508 - 020644)\",\"TRAFFIC_TYPES\":1}}],\"crs\":{\"type\":\"EPSG\",\"properties\":{\"code\":\"3011\"}}}"
> It seems very likely the problem is that IE in Quirks mode accept loadXML even when the input is JSON, but will reject such in strict mode.
> I will look into using a <meta http-equiv="X-UA-Compatible" content="IE=10" /> directive or something similar to make sure Quirks mode is enabled for my OpenLayers application.
> Per-Anders Staav
> Systemutvecklare
> Mobil: 0768-44 10 36
> per-anders.staav at norconsult.com
> Norconsult Astando AB
> Hantverkargatan 5K
> 112 21 Stockholm
> www.astando.se
> <image001.png>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20141120/09057ddc/attachment.html>
