[OpenLayers-Users] Geoserver / Openlayers : Front-End interface
Imran Rajjad rajjad at gmail.com
Sat May 9 03:45:02 PDT 2015
Hello,
if there is no server side in your application, you might want to take a
look at Aptana IDE, its built in Eclipse
http://www.aptana.com/
regards,
Imran
On Sat, May 9, 2015 at 2:22 PM, ELKHATTABI Imane <imanekhtb at gmail.com>
wrote:
> Hello,
> I am using Geoserver as cartographic server .
> I'd like to make a  client side  interface using Openlayers,Ext,Geoext .
> That can select by attributs the layers published on Geoserver as WMS ,
> and display the result on a map (openstreetmap).
> Whitch IDE to use for this purpose: Netbeans or Eclipse ?
> Thank you in advance
> ᐧ
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
I.R
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20150509/213a69b0/attachment.html>
