[OpenLayers-Users] Refresh map after updating chart elements
Jürgen Dankoweit
Juergen.Dankoweit at T-Online.de
Thu May 14 23:42:32 PDT 2015
Am 15.05.2015 08:26, schrieb Tom Ruff:
> I think Juergen means layer.redraw(true). That should work.
I have tried this too after spending hours of searching and testing for
a solution - this was about two years ago. But this solution works only
when the zoomlevel changes or the map is panned.
Only <layer>.refresh({force: true}) did/does the trick.
In OpenLayers3 there is the same problem.
> -----Original Message----- From: Jürgen Dankoweit
> Sent: Thursday, May 14, 2015 10:20 PM
> To: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Refresh map after updating chart elements
> Hello Jason,
> Am 14.05.2015 21:01, schrieb Jason Hawkins:
>> need to refresh an openlayers map after updating the size of pie
>> charts in a mapfile displayed on the map (on button click). I cannot
>> refresh the whole page or I lose the data. It works when I change the
>> zoom level. I have tried map.updateSize() (no effect), map.render()
>> (TypeError "a" is not defined), layer.redraw().
> The methode "redraw" does not work as expected. Myself ran into the same
> trap. For me calling <layer>.refresh({force: true}) did the trick.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Best regards
> Jürgen
> Homepage: www.dankoweit.de
> Users mailing list
Mit freundlichen Grüßen
Jürgen Dankoweit
