[OpenLayers-Users] Refresh map after updating chart elements
KS ks at designers.pl
Thu May 28 03:00:04 PDT 2015
Jason Hawkins wrote:
> Perfect! <layer>.refresh({force: true}) works for me.
> On Fri, May 15, 2015 at 12:42 AM, Jürgen Dankoweit
> <Juergen.Dankoweit at t-online.de <mailto:Juergen.Dankoweit at t-online.de>>
> wrote:
>     Am 15.05.2015 08:26, schrieb Tom Ruff:
>         I think Juergen  means layer.redraw(true).  That should work.
>     I have tried this too after spending hours of searching and
>     testing for a solution - this was about two years ago. But this
>     solution works only when the zoomlevel changes or the map is panned.
>     Only <layer>.refresh({force: true}) did/does the trick.
>     In OpenLayers3 there is the same problem.
>         -----Original Message----- From: Jürgen Dankoweit
>         Sent: Thursday, May 14, 2015 10:20 PM
>         To: openlayers-users at lists.osgeo.org
>         <mailto:openlayers-users at lists.osgeo.org>
>         Subject: Re: [OpenLayers-Users] Refresh map after updating
>         chart elements
>         Hello Jason,
>         Am 14.05.2015 21:01, schrieb Jason Hawkins:
>               need to refresh an openlayers map after updating the
>             size of pie
>             charts in a mapfile displayed on the map (on button
>             click). I cannot
>             refresh the whole page or I lose the data. It works when I
>             change the
>             zoom level. I have tried map.updateSize() (no effect),
>             map.render()
>             (TypeError "a" is not defined), layer.redraw().
>         The methode "redraw" does not work as expected. Myself ran
>         into the same
>         trap. For me calling <layer>.refresh({force: true}) did the trick.
>             _______________________________________________
>             Users mailing list
>             Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/openlayers-users
>         Best regards
>         Jürgen
>         Homepage: www.dankoweit.de <http://www.dankoweit.de>
>         Users mailing list
>     Mit freundlichen Grüßen
>     Jürgen Dankoweit
>     Users mailing list
>Users mailing list
Also try
mylayer.mergeNewParams({ 'timestamp': new Date() });
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20150528/af1124cc/attachment.html>
